Wobble under braking
How about rain?
How many miles is your commute? Does this only happen at the beginning of your drive?
A bent rotor would be a constant problem no matter temperature, weather, speed, etc. A bent rotor can also cause a rhythmic noise as the wheel turns. It could be a squeak, a metal on metal clank or a subtle rubbbing groaning noise. After a lot of miles you will see the brakes pads on the bent rotor worn unevenly. That takes a lot of miles to happen though.
How about rain?
Stated in first post it happens just first part of your drive and then goes away when almost to work? I wouldn't think it would be a bad rotor, it would do it all the time. Try some different routes to work maybe, and rotate tires make sure all front end parts are tight, did you install any parts recently?
1 Post
Ok guys im unsure if this is really death wobble. Every morning on the way to work when i brake for a light or car etc.... i get a light shimmy to a hard wobble in my steering wheel and by the time i get to work it seems to subside. Again this is only during braking not while hitting bumps etc.. Anyone have any ideas or fixes?
