Wobble at 55 MPH
Old 02-17-2013, 02:48 PM
  #61
JK yeti's Avatar
Looked at my tierod today and the axle side link is bad.. Is that causing the wobble??
Old 02-17-2013, 04:02 PM
  #62
miethead's Avatar
Just last week I started getting a really bad shake that only occurred at 40-45 mph. Had tires balanced again, and it was still there. Long story short both tie rods were shot. After I replaced them the shake was gone.
Old 02-17-2013, 06:34 PM
  #63
JK yeti's Avatar
Cool! I checked my tie rod and it was tight no loose or unnessisary movement!
Old 02-17-2013, 06:43 PM
  #64
Jeek.OlllllllO's Avatar
I had a wobble and i had lost a weight so i just got my tires balanced
Old 02-18-2013, 02:53 AM
  #65
JK yeti's Avatar
Already had them balanced and rotated!:(
Old 02-18-2013, 01:57 PM
  #66
Ball joints? Tires? Bolts? Northridge 4x4 sells a kit with bigger bolts for like 30 bucks
Old 02-18-2013, 03:19 PM
  #67
JK yeti's Avatar
Already have the northride bolt kit! Just orderd new draglink so we will se if that solves the problem!
Old 02-18-2013, 03:45 PM
  #68
jeepsta's Avatar
How do u now if tie rods r bad or drag link will it move up and down with pry bar or should it not move mine moves a little.
Old 02-18-2013, 04:10 PM
  #69
JK yeti's Avatar
Get some one to turn the steering wheel back and forth while your under the jeep. Inspect all joints. You can actually hear, feel and see where the draglink is bad and you'll be able to tell if your tierod is bad to!
Old 02-18-2013, 09:45 PM
  #70
xed
xed's Avatar
Welp.. Go the tires rotated and balanced and.... Its still there.. Pooop what do i do now? I have an appointment for an alignment later this week
Also my tires are very worn and there all worn unevenly. Will that cause this?
Sorry for responding to this thread so late in the game but... YES!!!!!
I bought my '08 JK Rubicon last year (February), they came with BFG KM2s that were already around 50% worn. By the following summer, I had shimmy/wobble when accelerating and I chased it with multiple attempts to fix it (new track bar, rotating tires, check over all bolts, blah blah). Finally fixed it by replacing the worn out tires with new ones.
Quick Reply: Wobble at 55 MPH
