Wobble at 55 MPH
So just recenly i put a new rough country steering stabilizer on my jeep. Love the feel of it and it coverd up my death wobble for now. But the day after i put it on the steering wheel and whole jeep begans to wobble at 55 mph? Doesnt do it a 50 mph or 60 mph... Checked for loose bolts dont know what else to do... Had the tires balanced about a month ago. Any ideas what it could be?
Originally Posted by Jeepkid850
So just recenly i put a new rough country steering stabilizer on my jeep. Love the feel of it and it cured my death wobble. But the day after i put it on the steering wheel and whole jeep begans to wobble at 55 mph? Doesnt do it a 50 mph or 60 mph... Checked for loose bolts dont know what else to do... Had the tires balanced about a month ago. Any ideas what it could be?
Originally Posted by BosoxJK
I had a wobble after my 2.5 lift was put on everytime I hit bumps in the road. I loosened all the control arm bolts and track bars the day after I had already torqued them and retorqued them and it solved my issue. Just check the bushings too
Speed related wobble is very often due to tires being out of balance. A steering stabilizer does not cure anything like death wobble. It only covers it up. The cause is still there.
OK, I must have misunderstood when you said it cured your death wobble.
Yes. Worn ball joints can be a cause of death wobble.
This link has some good info:
[h=1]DEATH WOBBLE : What it is, What it isn't and What You Can Do to Fix it[/h]
Every wobble starts with something that rotates and is out-of-round or out-of-balance or both.
Once the wobble starts:
- loose bolts,
- bad bushings,
- worn ball joints,
- worn tie rod ends,
- loose shock mounts,
- wheels bearings,
- a worn steering box,
- loose or shot steering damper
- and pretty much anything else that moves
