Wiring question
Wiring question
I replaced my stock front bumper with the new Body Armor bumper. I am using some aftermarket fog lights. My question is how to wire these up to the wiring loom that goes to the stock light controls on the steering column. There are two wires in the loom, one black and one white. My lights have just one wire in each, red. How do I proceed....
Use the wires that controlled the stock fog lights. Red is hot and you will need to ground the light from the post if the bumper does not have a ground. Also you will need to run a relay if the power of the new lights are much stronger than the old lights.
Black should be ground you will need a relay to control the new lights just use the white wire to power up to new relay to control the new light that way it still turn on like factor fogs do
OK so from the factory loom which wire is which? There is a white wire and a black wire....
