Windshield Light mounting brackets...which to buy?
im finally about to invest in some windshield lights.. More than likely KC Slim Lights..
what mounting brackets is everyone using? what mounting brackets is everyone using? any advantages of one brand over the others? any one have any horror stories with their rusting prematurely or anything?
I have a pair of Hella 500 FF mounted on MBRP brackets. The Hella lights have a pretty bad halo effect the throws light into the cabin. If you put the grill covers on them its better. The KC long range would be a much better choice. The brackets started rusting almost immediately. I just refinished them this weekend. I would recommend a different brand.
I have the Mopar brackets with hella black magic 1000s.
Pros- They move the lights low and to the side of the windshield.
Cons-expensive and you have to bend the stock antenna or get a stubby.
I believe the smittybuilts are exactly the same, but for half the price.
http://www.quadratec.com/products/12110_3000.htm
I use the the KC slims with the KC brackets. brackets are fine but the mounting hardware of the lights had rust after about a year, maybe less. not sure if anyone else had an Issue or if it's just me, could be caused by all the road salt here during the chicago winter. sanded off rust and sprayed with a few coats of rustoleum, hasn't come back.
I went with the HiDX brackets. They mount down and out, and include an antenna bracket to route it away from the light.
No problem with a drivers side rugged ridge mirror relo. (not using the passenger side mirror bracket, but I don't think there would be a clearance issue with the antenna bracket, as it is in and up from the mirror)
