Winches with Air Compressors
For the past few weeks I have been looking at winches. I've read the posts about synthetic line vs cable and all the pros/cons. Now I am contemplating the idea of getting a winch/compressor combo. The main reason for the compressor would be to fill my tires after I air down. Its the smittybilt xrc 10 HD winch and comes with coil hose, fittings, and 2.5 gallon auxillary tank. I was looking at the smittybilt xrc 10 comp series winch, but I can get this one at the same price.
One thing I did notice is the comp series winch has synthetic line and a 218:1 ratio while the compressor winch has cable with a ratio of 148.2:1. I dont want to sacrifice performance just to have the compressor....I can always get one separate. They are the same price so my question is $550 which one is the better deal?
The Warn Powerplants come with an onboard 1/2 gallon tank. It's built right into the winch and you never see it. This helps make the PP a little better than just a regular compressor. It works great for airing up, resetting beads, I've never used pneumatic tools on it.
Personally, if I was going to go through the trouble of mounting a real tank, I'd probably go with an ARB or Viaire system over a compressor on the winch. I don't know about hte XRC but with the PP you have to manually switch over the motor from air to winch, so if you in winch mode you can't air up your 2.5 gal tank without stopping and swithcing over.
I had no intentions on getting a PP but I was suprised for x-mas and I'm not going to complain. But there is also the idea of isolating the two system so if your winch breaks, you still ahve air and visa versa.
I do like having an easily accessable air connection though. With an ARB you ahve to pop the hood to get to the compressor unless you get tricky and plumb in a disconnect up on the grill or something.
i know i am highjacking my own thread, but can you post a side view of your bumper and the winch. i am waiting on my LOD midwidth to come in and I wanted to see with the powerhouse how much clearence you would have between the winch and bumper hoop to mount lights beneath the winch hoop.
keep in mind that if your winch breaks and you need repair, you will loose the compresor also or if the compresor breaks, u loose your winch. something to think about.
personally, i would keep the winch seperate from the air compressor. you can still buy a good winch, compressor, and 2.5 gal air tank and all the parts etc.. for less than getting the warn powerplant.
edit: ok just checked out the smittybilt xrc 10 HD winch, that seems like a pretty good combo. without pricing everything out, i dont know if u could buy everything seperate and be cheaper or not. but i still say keep air and winch 2 seperate systems if u can
Hey
The midwidth includes a place to put lights on the top of the tube that goes over the winch.
Here is a front on pic with the mount points circled in red
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
