Winch in wet cold weather
O i recently purchased a winch and im looking for some suggestions on how to protect it from the elements specifically in the winter. Any help would be appreciated. At the moment it has cable but i will soon be moving to synthetic
Several companies make covers for them to keep the elements out.
I have heard that depending on the breaking and gearing of the winch, you can not switch from cable to synthetic line on some winches due to the heat caused by operation, make sure your winch is able to work with synthetic before spending all the on the line.
Hope this helps,
Happy Jeeping.
Hope this helps,
Happy Jeeping.
Wire scratches surfaces, while synthetic needs completely smooth surfaces, such as the fairlead.
Keep it covered - this goes for summer sun as well.
If it touched sand or mud, wash it real well so no sand particle stay in it, then let it dry, then reel it in.
Do NOT use a hot air blower on synthetic.
Also, with my steel cable, I don't have a cover, as I live in south Texas so snow/ice build-up is not a concern, I do regularly inspect the line, and keep it oiled up with 3 in 1 oil.
I tend to go a bit overkill with such things, every few months I unwind, inspect and oil it. About once a month I oil it still on the spool. Had it a year never covered, the Jeep lives outside not in a garage, used it 5 or 6 times, cable still looks brand new.
