winch on stock bumper
www.roughcountry.com/install/1173.pdf
it appears that you only have to cut anything if you don't have the factory tow hooks.
I was looking at the winch mount for that and have a couple of ???'s.
I just installed a Curtis front hitch and I believe it uses the same holes on the frame rails to mount the winch.
The hitch had about a 1/4 " play side to side inside the frame rails, I was thinking if the winch plate was a tight fit, I could shoehorn the plate and the hitch into the same holes. How was the fit of that plate?
Thanks.
Thanks.
