winch mount
You can also get a universal winch plate for cheap but it requires some cutting or trimming. As mentioned earlier, Rough COuntry is a good piece as well as the Rugged Ridge.
Former Vendor
Former Vendor
The tricky part about a receiver mounted winch is you can safely only pull in one direction. A winch plate gives you more recovery angle options as you are pulling from the frame of your Jeep, not a single point like a receiver.
my issue with a hitch mount is basically you are limited to aftermarket bumper with receiver hitch for the front and for the back unless you have a aux battery in the back you end up with a pretty long set of cables going to the battery to the winch and shorter is better. Most of the Costco type kits I have seen that sell cheap champion winches for this have low grade cables and that is not good either. I know Warn makes a kit so they must have faith in that set up but not what I would call ideal. My one and only bitch with the RH4x4 is the powder coating is pretty poor. mine is 2 years old and rust pretty much bleeding thru on all surfaces. that said I recommend them all the time and I am responsible for selling at least 6 of them in the last 2 years.
I have the Rock Hard mount on my stock bumper, along with VDP stubby end caps. I use my winch regularly and have had zero issues. It's a great product. I have zero regrets.
