Winch help please
Winch help please
Hey guys,
I have a smittybilt xrc8 winch which I got last summer and it worked fine then. Over the winter months I covered it up and did not use it. Today I decided to uncover it and check to see if everything was working and what not. I plugged in the remote and turned the clutch to engage and hit the in and out button and neither worked. The light on the controller lit up though. So.... I decided to check to make sure all the cables were getting power. Took apart the box and checked all those connections and they were fine, checked all the connections on the winch and they were fine. All had a current as well when I checked.
Any ideas what could be wrong? Maybe something with the clutch or am I just missing something? I'm new to winches and have only used mine once since I've had it.
Thanks,
Dom
Thanks,
Dom
the Smitty winches require you to plug in the remote and twist it 1/4 turn to lock into place. If you have already done that, i would suggest the same as the above poster and make sure your contacts aren't corroded. good luck!
Thanks guys for both your responses. When I first bought it I admit I didn't get the twist it part at first lol, but now I know. Contacts look alright, not sure what a thermal switch is? Anyone care to explain?
This might sound dumb, but are you sure you had the remote plugged in right. It's very easy to plug it in upside down. I've done it. All the lights lit up, but nothing worked.
Exterior connections are tight and everything is hooked up correctly. Pretty sure I had everything in the correct way but maybe I put it in wrong, I'll try again tomorrow just to make sure. I'll probably give smittybilt a call tomorrow if nothing else works. Thanks again guys for all the replies.
Dom
Dom
Tried again today, put the remote in the other way and nothing. Had it right the first time. When I put it in and hit either button this time I heard a little clicking it sounded like but after I hit the button about 4 times it went away. Light still lights up green and red. I'll have to give them a call. Been very busy though and haven't had time.
