Winch Circuit Breaker Install
Old 01-28-2016, 02:30 AM
  #31
14Sport's Avatar
Originally Posted by adamisadam
check this out
https://youtu.be/mX-_rM4Y2Mc?t=14m27s
they used 500 amp fuses for each winch.
That's great. I'm glad to see they used a Warn power interrupt for the front and rear jumper cable hookups and the front winch. That's what I have and I was concerned with the load capacity of the solenoid but I'm good. Thanks!
Old 01-29-2016, 07:53 PM
  #32
RockZJ's Avatar
Very informative thread. I think any of us who have a winch or run one in the past has had this question cross their mind. I have my positive terminal disconnected from the battery unless I am heading off into the woods. This might be the trick for my VR8000-S. Glad someone bumped this old thread.
RockZJ
Old 01-30-2016, 09:50 AM
  #33
adamisadam's Avatar
I installed the breaker. I bought 12" of pre assembled, marine grade 2ga wire. I put a loop in it which seems to keep everything tightly in place. I also taped the neck out of it to avoid accidental contact. I feel better knowing it's not live 24/7 now.
Feedback welcome.
Old 01-30-2016, 10:31 AM
  #34
YJ-JK's Avatar
Originally Posted by scooby snacks
I installed a Warn Power Interrupt switch. Here's my install video.
YouTube Link: https://www.youtube.com/watch?v=bOjnGm0MFWo
X2 on the warn interrupt. I hooked it up to my sPod and it works perfect, so far. I can feel the thump when I switch on the power.
Old 01-30-2016, 11:59 AM
  #35
Mr.T's Avatar
Feedback welcome.
Looks good, have you tried good pull yet? BTW, if you ever replace battery terminals, the Quadratec terminals work nice.
Old 01-30-2016, 12:37 PM
  #36
adamisadam's Avatar
Nice terminals.
No, I haven't even tried the winch. That would have been smart. Duh. It was getting cold so I just wanted to finish.
Old 01-30-2016, 12:52 PM
  #37
Mr.T's Avatar
Know what you mean, it's only a couple degrees warmer here in the PNW. Come on springtime
Old 01-30-2016, 02:34 PM
  #38
Ripa777's Avatar
Installed mine today. Must've gotten a bad part. Winch works when connected to battery. Sucks
Old 01-30-2016, 03:33 PM
  #39
Mr.T's Avatar
Bad parts always mess up the fun! Curious if the switch lever stays in the on position when turned, or is it loose like it's broke inside?
Old 01-30-2016, 05:31 PM
  #40
Ripa777's Avatar
Ran it to my sPOD.
Quick Reply: Winch Circuit Breaker Install
