Wilwood brake kit
exfruitlogoguy (04-06-2022)
#22
I just put on the Teraflex Big Brake kit (new slotted rotors, and two piston calipers) not just the big calipers and bracket. I already had the SS brake lines on. First off , these are big, the most important thing to remember is that you have to bleed the ABS, this is either done at the dealer or you have to cycle the ABS by finding a gravel road or wet grass and cycling the system about 10 times. The dealer did mine for free since it was in for something else. Once the ABS was bled they felt like stock with the stock tires (I have 34"). I DID NOT replace the master cylinder on my 2012 and I have no problems. I would recommend these, shop around I bought my kit in the low $600 range free shipping.
You got lucky and the dealer gave you a free bleed. From what I've heard, it is usually very expensive for the dealer to do it.
#26
Completely different mounting . These are by far the most expensive system. I'd say for the enthusiast. If you haven't driven a car with brakes like this you wouldn't understand what you are getting into. Don't forget the fact regular automotive stores may not have parts or pads.
#27
