Will TJ hinges fit a JK?
OK, with the nice weather I'm itching to build my own tube doors/half doors.
Has anyone tried to see if TJ hinges would work on the JK? They would be a lot cheaper than replacement JK hinges.
If you are building tube doors you dont even need hinges on the door. You could use a rod or bolt that fits in the hinge on the jeep. Even cheaper than a TJ hinge.
