Will these fit
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
1 Post
Would spacers help with these tires or spacers and a small lift?
Im thinking about going the 285 size on my 09 is the reason I was asking.
Also curious as to how much backspacing the stick 18" rims have.
Thanks.
Thanks.
JK-Forum Founder
yes, running a set of 1.5" wheel spacers will help give your rear sidewalls more clearance from the swaybar links and allow you to make a full turn without rubbing. depending on the tire, you may still rub the air dam on the corner and you will most likely see some rubbing at a full flex. a leveling kit or small budget boost will help prevent this.
1 Post
Thanks Eddy.
If it just rubs on the front, that could be trimmed so it wont
or changed out.
The specific tire I was thinking is either 265 60 18 or 265 70 18 Wild Peak.
The size is just slightly bigger than the stock tires I believe.
or changed out.
