Will a Steering Stabalizer Help Much?
I did a quick search and did not find a suitable answer to my question...so here it goes.
I have 2dr with TF 2.5" BB 33"s on 16" wheels....I have loose steering as expected from the lift and bigger tires...My question is...Is a steering stablaizer worth it? What exactly will it do? What brand do you have/ suggest? What is the difficulty of the install? I have seen the RC dual stabalizer...what is the purpose of two?
Thanks for your help.
i have a bds single stabalizer and it made a big difference for me. i have 35 " mud grapplers, i think a single stabalizer would help you out alote. i dont think your tires are big enough you would need a dual one. they are easy to install . good luck.
while a steering stabilzer will "help" to hide loose or flighty steering, it will not fix it. if your suspension is dialed in correctly, you really don't need a steering stabilizer at all. adding more positive caster will help address your steering woes and i would address that first.
