will my tpms form stock rims work in after market wheels???
My stock TPMS worked in my Mojave wheels. I did need a rebuild kit, since the seals have to be broken on the TPMS in order to switch them over. It was like only 12 bucks anyways.
I am not sure if tpms will work on bigger wheels, but I know they work on smaller wheels.
I have 16" procomp soft 8 steels. OE TPMS from stock 17" akuminum rums fit fine. Took a few miles of driving to get the light to go out after the change over though...
update tpms did work on the new procomp wheels. however now on one tire would balance all the other four where way out of wack freaking 20+ ounces ... WTF
You might want to check and see if they were mounted right. Check for a red dot on the sidewall or some other marking. It is the spot where the manufacturer says the valve stem should be. If its not mounted properly in this area, your wheels will need additional weights
yup.. im so pissed .. even had them reset their balancing machine to make sure something didn't happen when they balanced the first one which balanced perfectly maybe 6 ounces needed. then every tire after was way off..
I guess im gonna have to try one more place. maybe an off road shop or something that has seen this before..
