Will I need to readjust my caster with 35s?
I recently installed my 2.5" coil lift with adj. front LCAs and rear UCAs. I am currently running the stock Rubi MTs (32"). I am currently running caster of 4.0 front left and 4.3 front right. Do I need to add more caster when I add my 35" MT MTZ (more like 34.5") and why if so? I need to be educated on this.
Additionally, do I need to readjust the rear pinion angle again as well? Thanks guys
Each jeep is a bit different but I would say no at that height. Tires have nothing to do with the caster, it would be the amount of lift you have. Mostly personal preference by the driver. If the steering feels fine to you then just leave it be. If it feels light then some longer lower control arms will allow you to rotate the axle a bit to regain some of the caster back.
In my experience 3" tends to be where you start needing longer LCA's to increase caster angle and fix wandering. Tire height doesn't matter, but inflation pressure and increased weight might make it handle differently. Rear pinion angle doesn't change with bigger tires either. Driveshafts are usually ok at 2.5" at least for a while. You really only need to adjust rear pinion angle if you use an aftermarket double cardan driveshaft since they are more prone to vibrations at greater angles than the stock rzeppa jointed shaft.
I just drove my rig 600 miles to OK and she handled well. No vibrations,wandering,etc. Well, other than being tossed all over the road when I was traveling across northern Texas. The winds were stupid. Having a 2 door does not help either.
My lift netted 3" over stock front; 2" rear. If all I need to do is slap the new meats on and adjust accordingly with the Bully Dog programer that I plan to get than thats good to know.
