Will this be enough to fix my caster after OME 2.5 standard lift?
Can I get a way with front lower control arms to get the caster to like 5 or 6 degrees? Would there be a need to use rear upper control arms? I'm thinking Rock Crawler right now. Thanks...
You won't need rear arms on an unlimited with the stock rear driveshaft. It pulls the rear axle abit forward when you lift it, other than aestetics, you really don't NEED them at that height.
Front lowers would be a go for that though.
