wild boar grill install questions.
hey guys my new wild boar grill came for my jeep today. im sure its a pretty easy install but is there any tips? i see have have to drill a hole in the front crossmember to mount the bottom of the grill too. anything else i should watch out for? thanks guys
Pretty straight forward. Pull the plastic rivets on the top of the grill, then disconnect the blinkers. Put the new grill in place to check fitment and to mark the hole to be drilled in the crossmember, remove grill, drill hole, then install.
