Wife just got death wobble.
Very common problem with that type of track bar adjustment. Every time I wheel and get a shimmy, I stop and the nut is always loose. If the red locktight won't hold it then next time..I will weld the damn thing!
Ok. So went and grabbed a bite after leaving the garage. On my way home while going up hill in 4 hi at 55kmhr I started to get a rythmic wobble feeling in the seat of my pants. My wife said hey do you feel that wobble feel? She said, that's what it started to do just before the steering wheel went crazy. So I backed off the gas. Stopped at a red light then continued up another long hill on the highway. I went back up to 55kmhr and the rythmic wobble started to come back. I slowed and by this time I was home. I havnt tried to see if it happens in 2 wheel drive yet.
I'd say it felt like an out of balance tire but the wobble was in the seat of my pants and not in the wheel. I didn't go any faster because I didnt want the full blown dw to kick in as I was traveling on the hwy with transport trucks.
I looked underneath at the drive shafts and took some pics. I don't have much lift so I dont think there should be any issues with them. I also grabbed the stock front lower control arms and gave them a firm shake. They moved slightly in the bushing about less than a mm but I think it wasn't so much the control arm moving as the rubber bushing flexing.
So I don't know what's going on.
Here's the pics I took of the front shaft.
Yeah after looking at the pics I see that. Why is the front shaft at such an angle? I just have a tf 2.5" lift that has sagged some since I got it on a year ago? If the front shaft was going and I had it in 4 hi would I feel it while driving?
For whatever reason, the tcase output is angled up a bit. Very common for that joint to fail. My guess is that as long as there is still grease in there, you won't feel it. When it starts drying out and gets noisy is when you would feel (and hear) something. Just a guess though.
Is your Steering Stabilizer ok?
I ask because I started to get the death wobble when on rough pavement/bumps/etc, and I finally diagnosed it to the stabilizer. It was/is leaking. I have another one on the way, but I'm sure it is just a mask of the real problem...
I know the Stabilizer shouldn't be need to prevent a death wobble, but I'm not sure my toe-in is correct. Trying to measure it with 35 MTR Kev's is tough with the big lugs on the outside.
I'm going to try and tackle the toe-in again and see if I can get accurate measurements. I think this is the cause of my Death wobble.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
Yeah the steering stabilizer is still good. I had a look at it on the rack last night. I've done a bunch more reading which leads me to believe that the front drive shaft might be the cause of the wobble I'm feeling in the seat of my pants.
It could be that the wobble and the DW were 2 separate symptoms caused by the wash board roads that I've been driving on in 4hi for the last 2 weeks. My wife said the wobble feeling in the seat started just before the DW kicked in at 60kmhr. After tightening the jam nut I test drove it and got it up to 70kmhr and no DW.
I didn't notice the wobble in the seat at that time because I was accelerating quickly. On the way home I noticed the wobble in the seat at about 55kmhr but I was accelerating slowly while going up a long hill.
