Wide tires on JK unlimited
I'm ashamed to say I don't understand the Bumpstop/Steering stops (My lazy ass should probably learn). Its just the standard cheap AEV 4.5 bracket lift, so whatever they do with the Steering/Bump Stops would be the normal install. I've run this wheel tire set up on all three of my JKS and have never had any rubbing. I haven't taken this one off road yet since I am waiting for a front driveshaft and Poison Spyder fenders for flex, but just driving on the street and Mall Crawling flex there is zero rubbing. Taking my previous rigs out there was never any rubbing at all (But I did have the pinch seam trimmed and flat fenders). I need to do a search on Bumpstop/Steering stop to find out what that is!
As for as more strain on the steering, I'd say yes. Slap your stock wheels on and turn the steering wheel w the engine off then try the same with 13.5" wide tires......quite a difference in force required to turn the wheel.
To the OP, if you're going to run a 14.5" wide tire, I would make sure you're you take into account your scrub radius. With that wide of a contact patch, it's certainly going to put a lot stress on your steering and you don't want to have your tires trying to move forward and back instead of just pivoting in place. In my head, I feel like you either need to run a taller tire (like 38’s or 40’s) or a wider axle with like 5" back spacing to maintain a reasonable scrub radius with a 14.50 tire.
Also - you'll likely need to look into hydro assist sooner rather than later.
Bumpstops are what limit your up travel (some use rubber pucks, or extensions for the stock ones). Keeps your tires out of your fenders or body, and protects your shocks from bottoming out depending on the collapsed length.
Because it's most likely what's commonly known as a mall crawler. I'm on 37's with 4'' BS on a 6'' lift and my front bumper is chewed up on both sides just from mashing at the dunes through some good whoops and landing off some little pansy ledges.
You'll want to learn about bumpstop so you can adjust yours after you put your PS fenders on. You should be able to increase your up travel a few inches assuming your bumpstops are correctly set now.
