Who is running 35s on 16 or 17 wheel with no balance issues?
see my sig..no issues so far...mine ore the 942 type D with 315/75/16 Maxxis tires.
edit...should note that I had my tires balanced/mounted at a local shop by a guy that owns and wheels a Jeep.
no issues
16" prcomp 7028's wrapped in 35" toyo open country m/t's and 1.5" spidertraxx. no issues at all. straight as an arrow and ZERO vibration.
maybe you have a bad wheel? try swapping the fronts for the rears and see if the problem persists...otherwise the only other suggestion i have is take it to a tire shop and have them spin the wheel with no tire mounted. that usually exposes the bad wheel instantly.
315/T0R17 BF Goodrich All-Terrain T/A KO's on MB Racing Chaos 17x8.5 Alloys all bought from Discount Tire. Quiet, smooth, and all-around better ride than the OEM 255/70R18 Bidgestone Duelers. I highly recommend them
