Who makes the best 4.56 set?
I just came across Revolution gears, read up on them and see what you think.
http://www.pirate4x4.com/forum/gener...8362?_k=qjgisg
been looking arround it looks like Spicer makes a 4.56 set i think i might go with those since dana makes the axles anyway. New question tho. MY jeep has just over 11k miles on it do i still need a full install kit or will just the ring and pinion with crush sleves be enough?
As long as whatever needs to be reused is not damaged while being caught in the back and forth.
With a good press and the right tools it's always possible. Me personally, some of my projects go terribly, not just the jeep. Having extras can hurt if you don't need em and spend the cash, or don't spend the cash and need em.
Even at 1k miles I would still go with the master kit. It comes with everything needed so it takes any worries away. You'll be able to use your own pinion bearings as setup bearings as well. In my opinion, it just doesn't make much sense not to.
