Who has this setup?
Who has this setup?
After lurking around for several weeks I pulled the trigger and have a few parts on order, all good choices I am sure, thanks to all the good posts from you guys and gals
I need a little help on the hard question , Does anyone have a good or bad opinion of the Rubicon Super-Flex 3.5 system. Looks as though it comes with everything you need except shocks. How good are the control arms, the pictures look pretty beefy!
My DD is an 07 Rubi 4door auto (van) We call it a "Limo"
Our only other driver is a 33,000 # 40 foot motorhome that we live in full time, so it would be kind of hard to be let down with the DD if I put it together wrong!
We enjoy Moab in Utah and Kofa in Az, and lots of other travels so we want a little lift.
Please help.
Thanks, Fred
Please help.
Thanks, Fred
This is definately something you should consider. I pull my 07 2-dr behind my 40' motorhome as well. I've had one instance where the Jeep got a little crazy while being towed. I attribute this to the fact that I didn't install adjustable control arms. After I installed the lift (OME - which gave me 4"), the steering became somewhat touchy. Turn in is very sharp and quick now. I've been waiting for warmer weather to upgrade my front lower control arms so that I can get the steering geometry back the way it should be. I use a simple A-frame tow bar attached to a Currie Industries skid plate/tow bar attachment plate.
control arms?
Here is a cut and paste from rubicons web site;
features include new Rubicon Express adjustable upper control arms and fixed lower control arms with our Super-Flex™ spherical ball joints, replacement lift springs extended bump stops, longer front stainless steel brake lines.
I am running the 3.5" RE Superflex on my 2 dr with OME long travel shocks. I love it. The control arms are very beefy and I see no drawbacks from having fixed lowers. The adjustable uppers allowed me to correct the pinon angle to accommodate Tom Woods drive shafts. Not sure if the drive shafts will be a concern on a 4 dr. Drives amazingly well both off road and on the interstate at 75mph. I moved up to 35" KM2s and have no rubbing, front or rear, at full flex. Good luck with your decision.
The RE fixed lowers are 'longer' than stock lowers. This gives the uppers plenty of adjustability to set your caster where you need it. (the adj uppers with stock lowers is where you may have issues with getting caster to an acceptable level)
I'm happy with it
I don't have any complaints about mine so far and have run this set up since late 2007.
I am an avid wheeler (not a mall crawler) so it has been flexed and tweaked to it's full potential.
Side note:
I was one of the many that had the "bad batch" of bushings, but they made it good and gave me all new once I figured out that was my issue.
~~~>So far so good
Side note:
~~~>So far so good
