Who has the best adj. track bar?
Sponsoring Manufacturer
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/teraflex-hd-forged-jk-front-adj-trackbar-35084/
Actually, it's not "new". Tera has used them for a while. I had one on my TJ back in 2002 that used the same sleeve adjustment. I loved it, but others I had read about had issues with the adjuster loosening under flex.
Yes, absolutely. It would be a minute amount, of course, but if you do not correct the axle first, which would be the reason the wheel is off center, then there would be a difference. However small. The steering box is centered with the vehicle at the stock ride height. As you raise the front, because of the track bar, the axle is dragged off center. If you do not re-center the axle with the track bar, and center it with the drag link, then you will lose a small amount of turn in one direction. It ain't theroy. It's fact.
my superlift 4" kit is coming with front and back.. the guy from summit said that I still need to use the rear relocation bracket that comes with the standard kit even with the adj. track bar.. thought that was the point of the track bar.... anyone's input would be good
I just ordered the full traction rear adjustable track bar. Only because Rubicon Express is still developing theirs and I don't want to wait 2-3 months. Next best thing Full Traction.
I have a Rubicon Express front adj track bar and have wheeled it a lot. No issues.
My lift came with a real hefty relocation bracket on the passenger side. Some of the kits I have seen put the relocation bracket on the drivers side, I heard that some of these are prone to breaking the welds off the factory mount at the axle.
It increases the lever arm on the mount without adding additional fastening point or distributing the load.
