Who can see light through the seams of the trextop nx?
The material they use contracts and expands a ton with cold and hot. I was able to install mine on a 60 degree day by fitting it most of the way and then blasting the heater for 30 minutes. It seemed like it expanded 2 inches lengthwise. This is on a jku.
Also if the gaps you are seeing are by the door surrounds, maybe the cables on the sides need to be moved to a different hole to tighten it up?
Here it is in the stitch
