Who’s got an Adams front driveshaft and how do you like it?
donjuan79 (03-29-2020)
I have the 1310 with solid U-Joints, non-greasable, install was easy. So far no complaints.
The bolts holding the old shaft at the r-Zeppa are many, and exceptionally long winded, but other than that all good.
Can't complain, feels beefy as hell. Haven't hit it on anything yet, I'm sure it is tougher than the stock tin can I pulled out. As far as drivability: as long as you keep your drive line angles out of the extremes it will be smooth as butter way on up close to 100mph. (Never had my Jeep over 97).
ease of install is exactly why I figured I’d just get the shaft rather than the stupid exhaust spacer kit and new CV. I would have broken those flange bolts and been up shit creek without a paddle lol. And having to put together the TF high angle CV wasn’t looking too fun either lol. This is a couple hundred more, but looks like a much easier job. I’m pretty sure it’s the one I’m gonna go with at this point. Thanks for the input brother 🍻
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
I recommend running a flange at the Transfer case. Depending on your set up and driveline angles you may not even need the double Cardone shaft. Most people don't take the time to measure and spend the extra $150 on a super maintenance item. Its nice to run a DC on rock crawlers to keep the pinion higher but on an overlanders, beach runner, fire road, daily driver a single u-joint end should work fine. Rear 2 doors might have angle issues.
I did break one of the exhaust flange bolts on the drivers side when I put my spacers in. Luckily for me, it was the drivers side, so I just ordered a loop delete that came with a new flange and went about my business.
![](https://babang.xyz/assets/8/o.png)
have both front and read 1310s. they're OK I guess.
my front drive shaft came loose at the transfer case. it shook one day on the highway that it grenade my transfer case. not trying to place blame on Adams, just stating the facts.
I guess I need to add that to my torque check list.
sent it back to Adams, they rebalanced it and fixed the u joint for a pretty penny.
again, just stating the facts...
