Where to mount resistor for LED front turn signals (it gets hot)
Where are you guys mounting these? I turned mine on unmounted and they get hot in 10 seconds. I was going to two side tape them to metal but that seems like a bad idea now.
I had mine 2 side taped and it melted off in no time at all. I have since removed these from my jeep cuz I didn't like how the back was open. The way the stock lights seal up seams like a much smater decision at least in the winter months. Sucks cuz I love the look of these LED
Luckily for me I live in the south then!!!
I thought about putting some dieletric grease in the socket, I did place the socket draining down so no water will pool in it. Also since this is not an everyday driver then I am not worried about that problem it is where and hot to mount these resistors and maybe if I need new ones.
Resistors reduce voltage by turning it into heat. 50watt is twice as much as a 25watt, it will be less hot, I don't know how much though, I've never been burned by a resistor, seen them blow up though.
Won't a 25 watt resistor basically use 25 watts of power, so that would equal the load of one standard blinker/tailight bulb. And the 50 watt would pull enough to equal two standard bulbs.
Are you telling me that the Jeep canbus system pushes out 26 watts to the bulb so if I use a 25w or 50w resistor both are just eating up the 26watts?
That is not how I know it to work. I was taught a 50 watt resistor eats 50 watts, doesn't matter if it is just replacing one bulb. So a 50 watt would theoretically get twice as hot but since it is bigger it disapates more heat so it would be about the same at the 25 watt on.
Am I wrong?
I guess I am stupid...
Am I wrong?
Am I wrong?
