Where did you mount your air tank?
Not unless you want to put it inside the passenger compartment. But then where would I put all my ??
Someone should design and fabricate a tank that is about 1" thick that fits across the full rear floor. 1"-1.5" thickness should get a couple gallons of capacity. If someone wants to steal this idea from me and make some $, simply send me one as a thank you. ;-)
It could be possible to fabricate a tank and essentially stick it anywhere...square, round, oval, the possibilities are endless... GENIUS, this guy is, 46chevytrcuk!
Anyone know if people have tried to seal and fill frame rails with air? I wouldnt think that would be too hard? That would be an awesome solution.
(Could be water storage too)
I've had this thought, a couple one gallons on either side in the rear like fire extinguishers, in fact with some ingenuity you could use fire extinguisher bottles depending on their ratings
I had that same thought! It's certainly thick enough that you wouldn't have to worry about the pressure. Not sure about water, though. You'd need to be 100% certain that it was sealed well on the inside to prevent rust and I don't think I'd drink or cook with water that had been in a frame rail. I'm not sure what it's coated with on the inside.
