When to use sway bar disconnect?
I have a 2016 JKU Rubicon Hard Rock edition with RK 1.5 lift and 285/70 17 tires. I tow this behind my MH. I usually run graded Forest Service roads and all the roads in Moab and Ouray with the exception of those rated as "extreme". Under what conditions is it desirable to use the sway bar disconnect, and what are the advantages in doing so? Thanks
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
In areas that you need mass articulation as in rock climbing or running steep off camber water falls. If you don't do this then there is really no need to disconnect and you actually get better traction for normal trails when both sway bars are connected.
I'm probably the exception, but I disconnect mine on any bumpy trail, regardless of how easy or hard it is for one simple reason, it smooths out the ride. When I get on a trail I hit the sway-bar button and pull it in and out of 4h to disconnect and smooth out the ride. We've had an '07, '12, '14 {still have}) JKURs (and now an '18 JLUR) and I've drove all of them same. We wheel local parks and go to Moab & Colorado twice a year (since '04) and I've used the disconnect 100x more than I've ever used the lockers. I will say that I don't do extreme trails, just all the popular ones in Moab like Gold Bar Rim / Golden Spike, PS, Kane Creek, etc.
Funny enough to Dirtman's comment, but the one area I won't disconnect is on steep off-camber hills where I want to minimize body roll. I know it still has the rear sway-bar connected but I don't like it when it gets to leaning / rocking too much or too easily.
On a trip a while back, the JK was getting thrown side to side quite a lot, even though travel speed was very slow. I disengaged the sway bar to smooth it out. One of the ladies in the back said "What did you just do to smooth this thing out?" The difference in ride was that noticeable.
This is counter intuitive actually. You get a lot more tippy a lot faster when connected in off camber situations. Keep those tires on the ground and let the body roll and you're much better off.
You'll roll the Jeep if you keep it connected when you're really off camber. Don't let the body roll scare you: if you've built your suspension correctly, you'll be fine.
Edit: I should add, I suck at trying to explain things. Of course if I'm stair-stepping down something off camber, I'll disconnect, even if it's not 'extreme'.
I'll be in Moab around July 29th this year so anyone is welcome to come out and play. But, we'll be in my wife's JLUR, which might still be stock, and we'll have the RZR1000, so we'll be in that most of the time. My JK on 35s will stay home.
Lol i disconnect any time im on dirt road with ruts. I put it in 4 wd and disco for that smooth level feel rather than be tossed side to side by being locked. Im not into rocks so its not a issue of needing to but, i agree Hip2u77 im maybe another exception. I do what seems to work best for me , granted if i didnt have the disco button id prob be locked more often (even getting to little spots on dirt roads) That arnt critical im disconnected for comfort and just 4l crawl in forward or backing up / then lock em up again where i need the stability. And i also rarely use lockers however when i did need them i had them, So im glad the option was there . Which was only 2 times in six years But northeast is totally different type terrain .
