Wheels/Tires on Stock vehicle help!
I am looking for a change from my stock 18" wheels/tires on my 2007 Sahara Unlimited to something that looks a little meaner ( and is a little better in NY winter weather.
I am not looking to spend a ton of money, but here is what I am thinking:
15 or 16" wheel on a good set of rubber.
any suggestions on what size I can go on a completely stock vehicle?
It is my first time doing a change like this, so I would like it to work on a stock vehicle- and I don't want to spend thousands.
Thanks in advance!
2007 Sahara Unlimited with 94k bone STOCK!
Thanks in advance!
JK-Forum Founder
bone stock, you can safely run a 32" tire or a 255 - no modifications needed. depending on the tire make, you might be able to go as high as a 33" tire or 285 but, you will most likely have some minor rubbing to deal with.
I am running 285 70 17's on my stock JKU and when I turn all the way either way my tires rub the sway bar a little bit. It's not a huge deal to me, but I do plan on a 2-2.5" lift in the near future.
I am running 33" -- BFG AT 285 / 75 / 16 on 16 X 8 rims with 4.5" backspacing. No rubbing on road, minor rubbing off road.
If you're looking to not spend much, you might want to consider Rubi take offs. They're 32".
Here's a link:
Jeep JK Wrangler Steer Stop Adjustment
Thanks in advance!
Thanks in advance!
Just make sure the 15" rims you choose will clear your brake calipers. MB72's are a popular rim in that size, and will fit fine.
You can get some 285's under your Jeep without a lift. For the rims, make sure you get 4.5" backspacing or less. The lower the #, the more your wheels will stick out from your Jeep. Your tire/rim combo will be cheaper if you go with the 15" rims.
are you going to take this thing offroad right away or take it easy.....Lift will be gonig on soon, but found these wheels/tires on Clist and couldnt pass them up...2000 miles on em and got all 5 wheels/tires with a 4" Rancho value flex lift for 2100 bucks! SOLD.....anyway im running a 34 and dont rub unless i try to flex across a ditch..normal daily driving zero issues
![](http://i692.photobucket.com/albums/vv287/Big_Smokey/Jeeptang/jeeptang.jpg)
They're awesome in snow (I'm in WI)...quite possibly one of the best tires for snow this side of Blizzaks. They do well in mud and rain, as well.
If properly rotated and aired, it's not uncommon to get 50K miles out of em.
They look more aggressive than most AT's.
They're one of the lighter tires you can run.
Price is decent. I got my 315/75R16's for $220 each. (Had to wait a month cuz they were on backorder, though).
Just be sure to check the PSI after you get em mounted. Tire shops routinely overinflate 4x4 tires...you want around 30 PSI for 33's. Do a chalk test to get it right on.
Good luck!
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
