wheel & spacers torque figures, etc.
washers
Do you have the Spidertrax spacers ? if so, the instructions will tell you to torque the nuts down to 97ft/lbs, then check them after 50 miles or so using 87ft/lbs instead. This way you're not breaking the loctite seal that is supposed to prevent the nut from getting loose. you should apply the loctite to the wheel studs before torquing down the nuts, this is done once, or if you take the spacers off the wheel , before putting them back on.
Get a habit of checking them every 5k miles same way. if you're having the wheels rotated, make sure sure to tell your shop to be careful with the impact gun as there are wheel spacers in there, getting the wheels off and back should be done the old fashion way, no impact guns. also before putting them in, make sure to clean the hub surface where they're going to be mated, and apply a very light bed of antiseize to the back of the spacers surface that would be pressed against the hub, this way they'll come off like butter if you happen to leave them on for a big while, you won't believe how this things can get literally fuzed in the hub sometimes
yes they are only there as they are used on the factory assembly line. you will not have your rotor fall off without them.
installing spacer
yup,saw those, took em all off...
it's rough country spacers...
the jk looks just right ,now... filled out...
thanks all for your help...
I got 9K miles...gonna search for rear diff oil change thread now....unless I don't need to...
jR
btw, the forum software or something is 'wrong'... it keeps missing my typing inputs... annoying as hell.... anyone else??
jR
jR
jR
