Are wheel spacers safe???
Old 01-06-2012, 09:59 AM
Jaraxal's Avatar
Thanks for the fast reply! Is there a consensus on a recommended brand?
Old 01-06-2012, 10:05 AM
mjones's Avatar
Spidertrax. Have installed several and no issues.
Old 01-06-2012, 10:10 AM
kesmith8's Avatar
RC here. 1 year and counting. Use thread lock and roll on.
Old 01-06-2012, 10:13 AM
BKGM Jeepers's Avatar
I've used custom machined steel spacers, and spydertrax spacers without issue. Be sure to apply red threadlock to your rotor studs as part of the install. Then it's smooth sailing. I'm currently running spacers on my rear axle and my spare tire carrier.
Old 01-06-2012, 10:18 AM
ArmyW4's Avatar
I have 1.5" Spidertrax spacers on my JK. I'm running 35's on stock rims and you need minimum 1" spacers to do that. I also run spacers on my 2004 TJ. Never had ANY problems with either. Just make sure you Loctite the spacer lug nuts and peridoically check them.
Old 01-06-2012, 10:23 AM
ShakyJake's Avatar
Originally Posted by Jaraxal
I'm new to the Jeep scene, so please forgive my ignorance. What does the wheel space do for you? I assume it allows you to put bigger/wider tires on?
Yes, if you are trying to use the stock rims, or rims with insufficient backspacing with larger tires, correct spacers will prevent them from rubbing. However, it is generally better to just buy aftermarket rims with correct backspacing and width for larger tires.
In terms of brands, Spidertrax are very popular and robust. BORA makes some of the best spacers I've seen and offer a lifetime warranty. I'm running custom ones on my trailer.
Old 01-06-2012, 11:52 AM
nthinuf's Avatar
Some light reading. Enjoy...
https://www.jk-forum.com/forums/show...pacer-Analysis
https://www.jk-forum.com/forums/show...-Spacer-Safety
Old 01-06-2012, 01:23 PM
OleBC's Avatar
Thanks everyone. I feel educated and a lot better about spacers.
Quick Reply: Are wheel spacers safe???
