Are wheel spacers safe???
Old 01-06-2012, 06:57 AM
OleBC's Avatar
Default Are wheel spacers safe???
Looking to put on 1.5" spacers in my stock wheels. Have heard from some spacers are not safe. Any thoughts?
Old 01-06-2012, 06:58 AM
JK-Forum Founder
wayoflife's Avatar
High quality wheelspacers, the kind that bolt up to your axle first are no more dangerous or cause any more stress to your axles then would a wheel with less backspacing. Anyone who tries to tell you otherwise doesn't know what they're talking about and I have yet to hear a single good or specific explanation as to exactly how they are worse. Just to be clear, the cheap-o spacers (the kind that you can get at PepBoys and are sandwiched between your wheel and axle using the existing wheel studs) are in fact EXTREMELY DANGEROUS. These cheap-o spacers leave little thread for your lug nuts to hold onto and can fail. DO NOT USE THESE!
Old 01-06-2012, 07:04 AM
ShakyJake's Avatar
^^ what he said! Also, even with the good ones, you need to check and re-torque regularly. Every tire rotation is a good opportunity.
Old 01-06-2012, 07:41 AM
OleBC's Avatar
I was planning on getting the ones from rough country. Are these ok. Trying to save a little money compared to the spridertrax
Old 01-06-2012, 08:04 AM
Jeepnut67's Avatar
Post
I've got the Rough Country ones... No problems for the past 3 months
Old 01-06-2012, 08:30 AM
J-VET's Avatar
I have the spidertrax and check the torque every time I rotate the tires. I have yet to find a loose nut.
Quality products = Quality results
Old 01-06-2012, 09:10 AM
Ryan0260's Avatar
Same here...
Old 01-06-2012, 09:37 AM
OleBC's Avatar
Thanks guys
Old 01-06-2012, 09:38 AM
Jaraxal's Avatar
I'm new to the Jeep scene, so please forgive my ignorance. What does the wheel space do for you? I assume it allows you to put bigger/wider tires on?
Old 01-06-2012, 09:44 AM
IndyChavez's Avatar
Yup! And the wider stance looks better.
Quick Reply: Are wheel spacers safe???
