Wheel spacers
Old 07-11-2012, 05:57 AM
eumel789's Avatar
Look at my tire web site. There is a drawing explaining all about tires and rims :-)
Click on "tires"!
Old 07-11-2012, 06:32 AM
Grant_T's Avatar
Originally Posted by Jeek.OlllllllO
Sorry if there's a thread already but my search doesn't work!!! So if i get wheel spacers i read i have to re tightened them every 100 miles is that true? And why do i need wheel spacers when i go to 35's and stock 17" wheels? Thanks
-Edgar
I am going to go out on a limb here and disagree with the concept of re-torquing them...at least to the original setting. I don't think they should have worded it that way as it could create a problem.
I agree you need to CHECK them at 100miles, and whenever your rotate thereafter, but if you originally bolted them on at 100 ft-lbs AND used loctite, then if you re-torque them to 100ft-lbs, you may risk breaking the bond the loctite has created.
I think they should have warned you to CHECK them at a lower torque on the follow-ups. I set my torque-wrench to about 10 ft-lbs less than the original spec and if they are still at least THAT tight, I'm good. I know I have seen other post the same advice here.
Grant
Old 07-11-2012, 06:40 AM
Tripletsi's Avatar
Grant is correct. It is stated in the Spidertrax instructions about this as well. I originally torqued my wheel spacers @ 95ft lbs with Loc Tite, then recheck them at 85ft lbs. Also it's a good idea to use a three step torque (using a star pattern), first at 30, then 60, and finally at 90. This will help to correctly center your wheel spacers (even though they are hub centric).
Old 07-11-2012, 07:54 AM
Jeek.OlllllllO's Avatar
Grant
Oh dam haha okay thanks alot guys sure help alot
Old 07-11-2012, 05:12 PM
Ryan0260's Avatar
I check mine at every rotate and balance. They haven't budged...
Old 07-11-2012, 05:45 PM
Nice where do you guys get loc tite?
Old 07-11-2012, 05:51 PM
mkjeep's Avatar
auto parts store
Old 07-11-2012, 05:59 PM
Originally Posted by mkjeep
auto parts store
Oh okay thanks
Old 07-11-2012, 07:58 PM
eumel789's Avatar
This is absolutely correct and should be followed to the "T", just like you are supposed to do the same to your wheels, even without spacers.
Quick Reply: Wheel spacers
