Wheel size myth busting
Old 03-06-2014, 05:06 PM
  #41
TheDirtman's Avatar
I would prefer this stuff to a bunch of poser shots with people saying what they are running. At least some actual information was relayed to the op.
Old 03-06-2014, 05:10 PM
  #42
stagedtrip's Avatar
Debate or a good back in forth is always good, there was plenty of info in a common question that everyone usually ignores or bags on the op for asking.
Old 03-15-2014, 06:26 PM
  #43
mhockey9090's Avatar
So going with a 16 or 17 inch wheel wont make any difference for light off roading will it? Im finding a good deal on a set of rims/tires that are 16inch Rims but i have always wanted to stay with 17s for some reason. IF there is not a big difference than i guess i can just go with a 16. Will i run into any issues with a 16inch rim and any kind of lifts out there?
Old 03-16-2014, 06:52 AM
  #44
Forum Tech Advisor
planman's Avatar
The difference of concern is how stiff the tires are, more than the wheel size difference between 16s and 17s. Try to avoid a load range E tire.
Old 03-16-2014, 08:44 AM
  #45
PG-JKU's Avatar
I went from an E rated 18" Duratrac to C rated 15" 33x12.5x15 Duratrac so have at least the benefit of running the same tire in two load classes so my comments might be valid.
18" E rated - harsh ride even at 20 psi. I was on stock rims mind you. Punctured tire on sharp rocks.
15" C rated - much better ride quality even at daily driving/ highway 35 psi. Airs down to 12psi offroad on 8" rims. No punctures so far.
Old 03-16-2014, 11:38 AM
  #46
Great info guys thanks.
Quick Reply: Wheel size myth busting
