Which Wheel Size?
Which Wheel Size?
Currently my '10 Unlimited has 17" stock rims.
I am thinking of upgrading tires and wheels.
My jeeps doesn't have a lift, and if I add one it will only be a couple of inches.
I plan on putting 32" tires on.
So my question is, is there any reason to stick with 17" wheels, or should I go to 16" and save some money on the tires?
Thanks for any input.
Ignoring the unmentioned tires size, in general you'll have more sidewall which will provide more space between the ground/rocks and the rim, but will suffer more flex. The former is good for a Jeep; the latter is generally irrelevant (For a Jeep. If you were talking a Mustang or such, that would be different).
When I bought my JKU , I went from stock 16" rim's to 17 " black rim's from the Mopar catalog with Rbicon size tire's . if I had to do over again I would had stayed with the 16" rim size like black steel rim's from Pro Comp . And had a better selection of tire's in 16" range to pick from, and saved lot's of money.
