Wheel/axle metal grinding noise...help
I just noticed this noise the other day and was rotating my tires when I discovered where the noise was coming from. See & listen for yourself at the following link. It's only the front left wheel that makes the noise. Any help would be much appreciated. It's parked until I figure out wtf it is.
https://youtu.be/Wsqy0z7AwtQ
![](/images/ranks/veteran_army.png)
Thanks, I'll take a look tomorrow. At least it's not a bearing or the axle.
I haven't noticed anything weird while braking...so hopefully it's a cheap/easy fix. But I say that about everything.
Thanks fellas! That was it. The top portion of the dust shield was rubbing. I just ever so slightly pulled the dust plate away from the rotor and wallah, no more metal on metal noise. Now let's hope my rotor isn't slightly warped.
![](https://www.jk-forum.com/forums/images/ranks/veteran_navy.png)
Before removing the wheel hub, try to bend the dust shield away from the disc. I had an issue where a piece of slag was between the disc and shield. Once I moved the dust shield it went away.
