wheel adapters + loctite.
A quick question for those of you with SpiderTrax wheel adapters. What type of loctite do they recommend? blue, red?
thanks,
Chris.
thanks,
Chris.
![Boss](https://www.jk-forum.com/forums/images/smilies/big_boss.gif)
...just put mine on twenty minutes ago after they've been sitting in the garage for 6 months, RED loctite and it comes in the box with all you'll need
![Post](https://www.jk-forum.com/forums/images/icons/icon1.gif)
Blue loctite is supposed to be removable and it is with a little effort but red permanent loctite can easily be removed with a little heat. Not too much heat or it could compromise wheel stud strength. Use a little propane torch, heat a little, and the nut should come off without an impact.
