Whats a good lift for 33s?
#22
#23
As far as the 33 vs. 35 thing. Some will say its a good in between (I used to be one of those) and some will say bite the bullet and go with the 35s, you'll want to after wishing you had (now one of those.) As far as lift, on 33s you don't need one really. 35s would take about 2" for light duty use. The backspacing of the rims is more critical than the height really, as is the tire width. You could also install flat flares and put 35s on with no lift (and maybe slight trimming to the rear pinch weld.) That would require aftermarket bumpers. 35s will make gearing issues more important as well.
#25
#28
2" is nice with 33's - RE BB with monoshocks
OR a 3" lift (OME HD Coil Spring Lift) is not terrible and gives you lots of room for flexing off-road and 35's!
