What will shock extensions gain me?
Have an 07 2 door X with a TF leveling kit and JKU springs running 33's
I was fortunate enough to have another member donate his Rubi shocks to me and am wondering if I should put extensions on them, but i'm just wondering what I will gain.
Would the ride be any different? Will all I gain is a bit of flex? I'm also assuming i'll need new bumpstops if I do buy them.
Thanks guys
Thanks guys
From what. I was told at my 4x4 shop,is if your running stock shocks, with any lift and no extensions to compensate for the lift, your risking distroying the shocks when fully extended. Idk how true it is, but I know I'm just going to replace mine when I lift.
Also from what I understand, the rear lift of a leveling kit raises about an inch, add a tad more for the JKU springs, however the rubi rear shocks are a bit longer than the stock rear X shocks, so i shouldn't need extensions for the rear, just the front
This is my understanding as well....allowing them to operate within their normal range and if fully flexed out, allowing them to extend the extra 2.5".
I am running this exact setup. Have the shock extensions to allow for a little more flex and Rubi shocks.
I have added some hockey pucks for bumpstops due to rubbing while fully stuffed.
I am happy with this setup
