What welder do i need?
#31
FCAW does have it's place, that's for sure, and with the addition of FCAW wires that utilize Argon based shielding gases, I believe they are going to be used more widely in the future (less fume, and spatter).
For the discussion here, I think the audience should know that you are mentioning dual shielded (Gas and Flux)FCAW wires, not the self shielded wires that most people at the garage level are familiar with.
Also I'm only familiar with FCAW wire down to .045" which might be a bit large for the jeep related jobs, and the machines they have at home. I'll have to pull up an operation range matrix and take a look., and see what other diameters (smaller) are avaiable.
Also for what it's worth Hobart and Miller are both ITW companies so some of the technology between the powersuppies are similar, Miller equipment usually has a few more bells and whistles however (rheostats vs. switchs for example).
#32
Looks like Miller does recommend .045" FCAW (dual shielded) down to 3/32" in material thickness.
And the voltage and current should easily be with in the range of the smaller machines.
http://www.millerwelds.com/resources...calculator.php
#33
Looks like Miller does recommend .045" FCAW (dual shielded) down to 3/32" in material thickness. And the voltage and current should easily be with in the range of the smaller machines. http://www.millerwelds.com/resources...calculator.php
#35
Ringer,
I see your from the Cleveland area, you don't work at Lincoln do you? I took my CWI exam there about 4 years ago, and have been to their automation building for robotic training in the past (I'm a welding engineer for a company in Buffalo, NY). I assume the "Hooley House" isn't too far from you? I can't remeber the other Irish bar I was in...
Back on topic...
For those that are new to welding Ringer is right Lincoln and Miller both have alot of information available. If your interested in welding, do some research, and practice. I have attached a good link for GMAW welding basics, and some arc theory as well.
http://www.lincolnelectric.com/asset...L-50/c4200.pdf
Back on topic...
#36
Ringer,
Back on topic...
Back on topic...
#37
Ringer, I see your from the Cleveland area, you don't work at Lincoln do you? I took my CWI exam there about 4 years ago, and have been to their automation building for robotic training in the past (I'm a welding engineer for a company in Buffalo, NY). I assume the "Hooley House" isn't too far from you? I can't remeber the other Irish bar I was in... Back on topic... For those that are new to welding Ringer is right Lincoln and Miller both have alot of information available. If your interested in welding, do some research, and practice. I have attached a good link for GMAW welding basics, and some arc theory as well. http://www.lincolnelectric.com/asset...L-50/c4200.pdf
