What welder to buy
#31
forum member "wildace" did his 1-ton axle swap using 120/flux core...... ----> https://www.jk-forum.com/forums/modi...d-swap-275195/ ....good for 1/4". You don't "have" to go 220... Lincoln Work-Pak https://www.weldingmart.com/reconditioned-work-pak-125
#32
I started on flux and an much happier with 75/25. To me welding on gas is smoother, has a better sound and leaves much less spatter. Also I didn't care for the fumes from the FC wire....
#33
Before I go further I will say I have a 220 miller with mixed gas that I never would
worry about the welds it lays down. It has served me well welding everything from my truss, building a car trailer, to odd jobs. With that said, a 110 will flux core will do everything you need without a problem if you know what your doing. I second the advice about taking a class at you local community college if you have one close.
#34
I just had a bit of a debate or argument if you will on another forum with ringer on the subject of welding c gussets with a 120v. Although it's not ideal, I say it can be done and has been done with great results. I also mentioned that since it's not an actual load bearing piece structurally in normal use that even if full penetration wasn't present it should be fine. He disagreed entirely and said that my thoughts were entirely incorrect. Take that as you will. I'm not an engineer or welding inspector but that was just my thoughts.
I respect Ringer's input. My intent isn't/wasn't to start a piss match but just to let the OP know that 120 has been used for something extensive as a 1-ton sas (solid axle swap) front + rear with success. I agree though, if you can do 220 it is preferred BUT 120/flux has been used with success as well.
all around
#36
#37
I respect Ringer's input. My intent isn't/wasn't to start a piss match but just to let the OP know that 120 has been used for something extensive as a 1-ton sas (solid axle swap) front + rear with success. I agree though, if you can do 220 it is preferred BUT 120/flux has been used with success as well. all around
#38
You can also just use a stock properly rated extension cord and make yourself an adapter. That's what I had to do because I have another 220V tool with a different plug. My issue was the reverse of yours where my welder has a drier type plug and my 220V socket was different. One of these days I'll get around to mounting it on the cart. And I use a Lincoln 180HD which I love.
#39
Just a heads up. Look out for incompatibility with AEV brackets and C gussets. On my 3.5" the gussets would have to be cut up to fit. Reason why I don't have C gussets.
#40
If I were you I would get a dual voltage welder (110 and 220). Miller and Lincoln make them. If you have the money there are a few MP (multi-process) machines that are badass. Lincoln has one. I can't remember the model number off the top of my head. With this unit you can mig, tig, and I believe ARC. I bought a Millermatic 211 (Miller obviously) and love it. It is 110 and 220. I usually leave it plugged into 220, but if I have some thinner metal to weld I use 110 as the 220 will just blow through it. I like the 110 also because it makes it somewhat portable. I've taken to my parents home to do a couple small projects and I've taken it to a lot where a trailer needed some welding.
