What type of Skid Plates?
I did the same setup. I also put on EVO Rockstars (more for the clearance) and have a set of front CA skids to go on. Need to get off my butt and get some C-gussets and I'll put them on at the same time.
I'm looking at a set of skid plates for my 2011 unlimited.
I have narrowed it down to 2 companies.
River Raider riverraider.biz/index.php?main_page=product_info&cPath=67&products _id=128
Or
Rock Hard http://rockhard4x4parts.com/jk-skids.html
I'm interested in what others are using if any.
Or
Looks like there are a few bolts attached to the block.
One concern I have is if the oil pan skid takes a hit it will transfer that engery to the block and not the frame.
As the others have pointed out the stock skids are more than adequate. I personally went with the Rockhard skids because I liked the added coverage they provided. I have the oil pan tranny and evap skids from rockhard. I like that the rockhard skids cover up the catalytic converters and the riverraiders don't.
Originally Posted by mtod
How hard was mounting the oil pan skid?
If you got the other skids too, you would need to drill (2) 1/2" holes in the crossmember and cut away about and 1" from the factory gas tank skid.
I haven't had any issues with over heating at all. The install was a bit of a pita because the directions weren't very clear. I've dropped it right on the skids and haven't had any issues. They are pretty rugged.
