What is this sound?
Old 01-10-2008, 05:36 PM
justinstoffregen's Avatar
nope. you shoulda' heard it when i turned the wheel back and forth after that pop...man, scary...
Old 01-11-2008, 07:26 PM
goose244's Avatar
It sounds to me like maybe you flixed you upper or lower control arms when you went into that rut. If you had a broken axle shaft you would have heard noises when you went through that last mud run spinning your tires. Doubt if you got a broken axle. Just sounded like typical flex noise like a bolt rubbing on something. Also check you track bar connections and brackets (Front and Rear) and make sure they are not cracked.
Old 01-12-2008, 03:17 PM
the dealer didn't find anything. I guess I just never realized how much noise the suspension can make. thanks.
Old 01-12-2008, 05:34 PM
0verride's Avatar
Sounds like a sway bar link. When they are connected at flex. If you had them disconnected, maybe it rubbed on something.
Old 01-12-2008, 05:45 PM
JackMac4's Avatar
broke an axle shaft????? are you kidding me?
sounds like that rock just dinged the differential or a control arm was just tweaked a bit..
take your jeep on some rocks and you'll hear a lot more of that..nothing to be worried about.
Old 01-13-2008, 03:47 AM
0verride's Avatar
Thats kinda what I was thinking too. added my 2cents cause the sway bar links is usually the sound you hear the most when wheeling.
Quick Reply: What is this sound?
