What size clamps to mount to Shrockworks Mid With..
I want to mount an LED light bar to the bull bar on the Shrockworks Mid-With bumper. Problem is, I just don't know what to get. I measured the diameter of the bar on the bumper and its 8 inches, but most clamps only go up to two inches?
http://www.offroadwarehouse.com/products/productID/37750
Can this be right? I could've sworn someone made mounts that will attach to the Shrockworks bar..
Last edited by Robar; 12-28-2008 at 07:51 AM. Reason: PLEASE DO NOT POST DIRECT NON SPONSOR LINKS
I think you mean the circumference is around eight inches - at least mine is. Diameter would be 8/pi = 2.5464790894703253723021402139602, give or take a little.
You need a clamp to fit a 2 9/16" pipe. OK, 2 1/2" would work just fine.
N2Rock, can I ask how you ran your wires? I got another set of lights for Christmas and was thinking of mounting them on the winch hoop like that (wish I had thought to ask Shrockworks to weld on another set of tabs), but I can't see the wires running from your setup.
Since I installed the first set all on my own , I have been told I have to figure out this set on my own too.
Thanks so much N2Rock. That should do the trick. Im assuming you bedlined yours since the ones on the website are silver?
