What should I modify to make the steering more like stock?
1 Post
I have a 2008 JK with 1 3/4 spacer lift and the matching longer shocks, and a 1.25 body lift, sitting on 35s. The shocks are relatively new ( 5K miles) and I threw on a fresh set of ball joints last week. ( The new ball joints improved some of the steering issues) The steering stabilizer is also relatively new ( less than 1 year old). The jeep steers OK in town, but at highway speeds it tends to get pulled easily by ruts and pavement seams in the road. (It does not get pulled to 1 side or the other on a flat smooth road.) Driving on the highway with only 1 hand on the wheel is tiresome and I commute about 94 miles a day, mostly highway.
Which of these mods should I be looking at next to make the steering more like stock?
- Pinion angle adjustment- Should I get adjustable LCAs or AEV geometry brackets to move the pinion angle back towards stock?
-Adjustable track bar- I'm running the stock track bar with no additional brackets, thus the axle is slightly off center.
- Would a toe-in adjustment help the handling?
-Something else?
Thanks.
-Something else?
Thanks.
Front lower adjustable CA's will help dial in your caster which should help the wandering when you hit road imperfections. Also you should check you toe in. A front adjustable track bar is always a good idea after lifting if your axle was displaced.
At that small of a lift, stock track bars are fine. They won't help your steering. IMO, with only 1.75" lift control arms are a waste of money. I'd wager your toe is off a bit.
Sent from some string and a few tin cans.
Measure your front tires off the frame to see how much your center of axle is off. Mine was 3/8" off and it was greatly improved with an adjustable track bar. Also have a friend help you wiggle your steering back & forth to look for play in your front end parts.
