What Shocks to Buy For Smooth Ride?
#81
Any chance you've measured your current ride height with your set up? Meaning top of the spring bucket to centre of bottom shock bolt on the front, and too of bar pin to centre of bolt on the rears?
I may have a line on some Rubi coils, numbers unknown at this time.
Just trying to figure out what I would yield vs what I have now.
Front measures 19.25" and the rear is 20.25.
Sahara with 16 / 58 and TF spacer level kit and stock shocks. Rig has 138,000 km.
I recall seeing a diagrams on JKF that noted front ride height bone stock should be 18.5". To my thinking my stock cols have sagged and I'm only 3/4" above stock ride height.
Bumpers are all OEM.
Cheers
#82
Kojack,
Cheers
Cheers
center of my front hub ie splitting the E's on Jeep to bottom of fender flares is just over 23" of front driver and 23" all others ie pass front and both rears.
#83
sounds like you are sagged a bit. my 18/60 coils I am at 20.75" in front (I have a winch and front skid plate so close to 100lbs on a stock bumper) and I am 21" on back with a heavy rear spare. I am 20 5/8" in front and 21" in back measuring those same points. Mine is an AEV 2" kit but it consists of the same as 2" spacer for front and 1" for rear (actually thicker spacer but you remove the stock isolator so gives the same) center of my front hub ie splitting the E's on Jeep to bottom of fender flares is just over 23" of front driver and 23" all others ie pass front and both rears.
This helps out a lot, I will invest the time to swap to Rubi coils with the understanding I should get bank to stock ride height (18.5")+2" spacer in front should get me to 20.5". Plus a stiffer coil and realize the Rubi coil is not taller then my Sahara OEM.
At the end of the day my Jeep will sit like a new Rubi with level kit, and I don't expect to match that of a 2.5" coil of course.
#84
I second this. I am running Monroe Reflex on my stock Sahara and it rides wonderful and handles well off-road.
