What saw for fender cutting?
I used a jigsaw with a fine down cut blade, it cut like butter. and a dremel with a small cut off wheel to finish the cuts. Just tape off the fenders as wide as the jigsaw deck.
Former Member
1 Post
4" grinder with a cut off wheel works best, pneumatic cut off wheel as well....sawzall with 22tpi blade WOR,s well but wavers a smidge....
Blue tape the fender draw your line and cut, the brace underneath lay a sawzall in at an angle and cut it off at a steep angle it works better than the cut off wheel to trim that part...
I used a dremel with the cut off wheel for the most part and the router bit for corners, then some sand paper on a block to finish edges.
Its more of a melting through process, go slow let it melt.
