What rocker guards (if any) will work with factory Rubi rails?
I am looking for something that mounts to the frame, not the body. Does such an animal exist? Thanks!
I've seen shrockworks rails ontop of the factory rails. You just need to specify that that's what you intend to do when you order and they'll build it so you can use both
The EVO rockers work over the stock rubi rails. It is a tight fit, but they work. Is there a reason you want both?
The Shrockworks can be made to fit over existing rails as long as you mention that when ordering (as someone else already mentioned). But the wait time on those can be way long..12 weeks+
